[GRASS-dev] Fwd: [OSGeo-Discuss] OSGeo-Live Press release 77: What's in the OSGeo-Live 11.0 reboot?
Moritz Lennert mlennert at club.worldonline.be
Tue May 30 06:01:03 PDT 2017
Markus,
AFAICT, you are the official contact point for GRASS in OSGeo-Live. Is
there anything we have to do on the GRASS side ?
Moritz
-------- Forwarded Message --------
Subject: [OSGeo-Discuss] OSGeo-Live Press release 77: What's in the
Date: Mon, 29 May 2017 23:56:36 +0200
From: Astrid Emde (OSGeo) <astrid_emde at osgeo.org>
To: Live Demo <live-demo at lists.osgeo.org>, Discuss
<discuss at lists.osgeo.org>, projects at lists.osgeo.org
29 May 2017
In line with the OSGeo-Live reboot [1] we have identified the following
actions:
We will only support a 64 bit distribution, (32 bit will be built but
not tested or officially supported).
We will no longer provide:
* Windows installers,
* Write ups for OGC Standards,
* Write ups for libraries without a user interface (on a case-by-case basis)
Stray projects: We haven't got a point of contact for these projects. If
you know something about this project, and can help review docs, then
please consider adopting the project. Without a volunteer, we will need
to consider retiring them from OSGeo-Live. Work commitment is low, kudos
and karma very high :)
* openlayers
* osgearth
* gmt
* iris
* jupyter
* JOSM (OpenStreetMap editor http://www.openstreetmap.org/about)
* proj4
* mb-system
* zygrib
Projects recommended to be retired from OSGeo-Live:
* geokettle
* geomajas
* javaworldwind
* kosmo
* mapnik
* pywps (quickstart broken)
* sahana
* tinyows
* ushahidi
* viking
Remaining projects:
* Most projects have at least minor tweaks required for the docs, some
have outright errors.
* We are asking each project to, check their project overview, run the
application on an OSGeo-Live VM (10.5 or a recent nightly build), run
every step of the quickstart, update if required, and tell us when done.
* Once verified, we will add the project back into the OSGeo-Live 11.0
builds.
* We will call on all projects to test their projects and quickstarts
again in an OSGeo-Live 11.0 beta.
For specific project comments, see the OSGeo-Live status spreadsheet,
column T "11.0 Comment", and column U "10.5 Doc Review".
[1] https://wiki.osgeo.org/wiki/Live_GIS_Disc_Press_Release_75
[2]
https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMlM8XtAOhUgcjZ7Y2O0FZc2H0/edit?hl=en_GB#gid=2014800150
Key Milestones
    5-Jun-2017	OSGeo-Live Feature Freeze (final application versions
installed)
   19-Jun-2017	OSGeo-Live delivered to UAT (final application versions
installed - Beta stage)
   24-Jul-2017	OSGeo-Live Final ISO
   14-Aug-2017 FOSS4G 2017 Boston
full schedule
http://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdE1SYUN3YWJ2N1NpSUczbW9IRWZNclE&hl=en_GB
About OSGeo-Live
OSGeo-Live (http://live.osgeo.org) is a Lubuntu (http://lubuntu.net)
based distribution of Geospatial Open Source Software, available via a
Live DVD, Virtual Machine and USB. You can use OSGeo-Live to try a wide
variety of open source geospatial software without installing anything.
You find this press release at:
https://wiki.osgeo.org/wiki/Live_GIS_Disc_Press_Release_77
Astrid Emde
Charter Member
Open Source Geospatial Foundation
http://wiki.osgeo.org/wiki/User:Astrid_Emde
Discuss mailing list
Discuss at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/discuss
Département Géosciences, Environnement et Société
Université Libre de Bruxelles
Bureau: S.DB.6.138
CP 130/03
Av. F.D. Roosevelt 50
1050 Bruxelles
Belgique
tél. + 32 2 650.68.12 / 68.11 (secr.)
fax  + 32 2 650.68.30
Bureau: S.DB.6.138
CP 130/03
1050 Bruxelles
Belgique
