[GRASS-dev] [GRASS-SVN] r70821 - grass/trunk/include/Make
Maris Nartiss
maris.gis at gmail.com
Wed May 31 08:25:58 PDT 2017
Hello Markus,
no idea, as it runs just fine on my system and I do not see any easy
to spot problem with test.c code. You should run it under valgrind /
gdb or just send me the core file.
Ah, yes, while at it, include also
/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/demolocation/.grassrc72
Setting all locale stuff to C should prevent failures when translated
strings are used or comma is the decimal separator thus it *should* be
harmless.
Māris.
2017-05-31 14:56 GMT+03:00 Markus Neteler <neteler at osgeo.org>:
> Hi,
> I guess I have to revert it:
> grass72_svn/lib/cdhc]$ make
> if [ "" != "" -a -f "".html ] ; then make html ; fi
> ==============TEST=============
> make test
> make[1]: Entering directory '/home/mundialis/software/grass72_svn/lib/cdhc'
> GISRC=/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/demolocation/.grassrc72
> GISBASE=/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu
> PATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/scripts:$PATH"
> PYTHONPATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/etc/python:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
> LD_LIBRARY_PATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/scripts:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/lib:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/lib:"
> LC_ALL=C LANG=C LANGUAGE=C OBJ.x86_64-pc-linux-gnu/test <
> test_numbers.csv
> TESTS:
> N: 30
> /bin/sh: line 1: 28663 Illegal instruction (core dumped)
> test_numbers.csv
> Makefile:19: recipe for target 'test' failed
> make[1]: *** [test] Error 132
> make[1]: Leaving directory '/home/mundialis/software/grass72_svn/lib/cdhc'
> Makefile:13: recipe for target 'default' failed
> make: *** [default] Error 2
> Any idea why this fails?
> Markus
> On Wed, May 31, 2017 at 8:47 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Yes, this one looks safe too, although it affects only compilation
>> running on non English locales thus a minority of users.
>> Māris.
>> 2017-05-30 11:44 GMT+03:00 Markus Neteler <neteler at osgeo.org>:
>>> Hi Maris,
>>> and, shall I backport this one?
>>> Markus
>>> On Sat, Apr 1, 2017 at 2:35 PM, <svn_grass at osgeo.org> wrote:
>>>> Author: marisn
>>>> Date: 2017-04-01 05:35:46 -0700 (Sat, 01 Apr 2017)
>>>> New Revision: 70821
>>>> Modified:
>>>> grass/trunk/include/Make/Rules.make
>>>> Log:
>>>> Enforce C language when running Python during compilation as LANGUAGE has a preference over LC_ALL.
>>>> Modified: grass/trunk/include/Make/Rules.make
>>>> --- grass/trunk/include/Make/Rules.make 2017-04-01 11:48:43 UTC (rev 70820)
>>>> +++ grass/trunk/include/Make/Rules.make 2017-04-01 12:35:46 UTC (rev 70821)
>>>> @@ -38,7 +38,7 @@
>>>> PATH="$(ARCH_DISTDIR)/bin:$(GISBASE)/bin:$(GISBASE)/scripts:$$PATH" \
>>>> PYTHONPATH="$(GRASS_PYTHONPATH)" \
>>>> $(LD_LIBRARY_PATH_VAR)="$(BIN):$(GISBASE)/bin:$(GISBASE)/scripts:$(ARCH_LIBDIR):$(BASE_LIBDIR):$($(LD_LIBRARY_PATH_VAR))" \
>>>> - LC_ALL=C \
>>>> + LC_ALL=C LANG=C LANGUAGE=C \
>>>> $(1)
>>>> # default clean rules
>>>> _______________________________________________
>>>> grass-commit mailing list
>>>> grass-commit at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-commit
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> Markus Neteler, PhD
> http://www.mundialis.de - free data with free software
> http://grass.osgeo.org
> http://courses.neteler.org/blog
