[GRASS-dev] [GRASS-SVN] r70821 - grass/trunk/include/Make
Markus Neteler
neteler at osgeo.org
Wed May 31 04:56:09 PDT 2017
I guess I have to revert it:
grass72_svn/lib/cdhc]$ make
if [ "" != "" -a -f "".html ] ; then make html ; fi
==============TEST=============
make test
make[1]: Entering directory '/home/mundialis/software/grass72_svn/lib/cdhc'
GISRC=/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/demolocation/.grassrc72
GISBASE=/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu
PATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/etc/python:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/scripts:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/lib:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C LANG=C LANGUAGE=C OBJ.x86_64-pc-linux-gnu/test <
test_numbers.csv
TESTS:
N: 30
/bin/sh: line 1: 28663 Illegal instruction (core dumped)
test_numbers.csv
Makefile:19: recipe for target 'test' failed
make[1]: *** [test] Error 132
make[1]: Leaving directory '/home/mundialis/software/grass72_svn/lib/cdhc'
Makefile:13: recipe for target 'default' failed
make: *** [default] Error 2
Any idea why this fails?
Markus
On Wed, May 31, 2017 at 8:47 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Yes, this one looks safe too, although it affects only compilation
> running on non English locales thus a minority of users.
> Māris.
> 2017-05-30 11:44 GMT+03:00 Markus Neteler <neteler at osgeo.org>:
>> Hi Maris,
>> and, shall I backport this one?
>> Markus
>> On Sat, Apr 1, 2017 at 2:35 PM, <svn_grass at osgeo.org> wrote:
>>> Author: marisn
>>> Date: 2017-04-01 05:35:46 -0700 (Sat, 01 Apr 2017)
>>> New Revision: 70821
>>> Modified:
>>> grass/trunk/include/Make/Rules.make
>>> Log:
>>> Enforce C language when running Python during compilation as LANGUAGE has a preference over LC_ALL.
>>> Modified: grass/trunk/include/Make/Rules.make
>>> --- grass/trunk/include/Make/Rules.make 2017-04-01 11:48:43 UTC (rev 70820)
>>> +++ grass/trunk/include/Make/Rules.make 2017-04-01 12:35:46 UTC (rev 70821)
>>> @@ -38,7 +38,7 @@
>>> PATH="$(ARCH_DISTDIR)/bin:$(GISBASE)/bin:$(GISBASE)/scripts:$$PATH" \
>>> PYTHONPATH="$(GRASS_PYTHONPATH)" \
>>> $(LD_LIBRARY_PATH_VAR)="$(BIN):$(GISBASE)/bin:$(GISBASE)/scripts:$(ARCH_LIBDIR):$(BASE_LIBDIR):$($(LD_LIBRARY_PATH_VAR))" \
>>> - LC_ALL=C \
>>> + LC_ALL=C LANG=C LANGUAGE=C \
>>> $(1)
>>> # default clean rules
>>> grass-commit mailing list
>>> grass-commit at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-commit
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
