[GRASS-dev] Different CRS matching in 7.2 and trunk
Markus Metz
markus.metz.giswork at gmail.com
Fri Nov 10 11:21:22 PST 2017
On Fri, Nov 10, 2017 at 6:43 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Nov 10, 2017 at 6:08 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> > Hi all,
> > I'm trying to understand a change of behavior between 7.2 and trunk.
With 7.2, I can do the following:
> > curl -SL http://fatra.cnr.ncsu.edu/foss4g2017/nc_tile_0793_016_spm.zip \
> > > nc_tile_0793_016_spm.zip && unzip nc_tile_0793_016_spm.zip
> > grass72 -c EPSG:3358 ~/grassdata/crs_test -e
> > grass72 ~/grassdata/crs_test2/PERMANENT/ --exec r.in.lidar
input=nc_tile_0793_016_spm.las output=count_10 method=n -e -n resolution=10
> > The last step (r.in.lidar) fails in current trunk because the
projection don't match. Here is the difference (name, datum and swapped
lat_1 and lat_2):
> > GRASS LOCATION PROJ_INFO is:
> > name: NAD83(HARN) / North Carolina
> > datum: nad83harn
> > lat_1: 36.16666666666666
> > lat_2: 34.33333333333334
> > Import dataset PROJ_INFO is:
> > datum: nad83
> > lat_1: 34.33333333333334
> > lat_2: 36.16666666666666
> > 7.2 considers this OK while trunk considers this different. I'm not
sure which one is correct.
> In this case, 7.2 is correct, but 7.2 does not compare datums, i.e.
projections would be regarded as matching even with e.g. nad27 and nad83.
> The comparison of datums is new in 7.3 and needs some refinement.
> I will fix the comparison of swapped lat_1 and lat_2.
Fixed in trunk r71656.
The test for different datum names has been disabled again in trunk r71657.
There are several different datum names in lib/gis/datum.table that
apparently mean the same: same ellipsoid and same transformation
parameters. Apparently, GRASS does not provide a datum name when converting
projection information from GRASS to proj4 for reprojecting data.
Markus M
> > Here is the lasinfo reference:
> > PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200",
> > GEOGCS["GCS_North_American_1983",
> > DATUM["North_American_Datum_1983",
> > SPHEROID["GRS_1980",6378137,298.257222101]],
> > PRIMEM["Greenwich",0],
> > UNIT["Degree",0.0174532925199432955]],
> > PROJECTION["Lambert_Conformal_Conic_2SP"],
> > PARAMETER["False_Easting",609601.22],
> > PARAMETER["False_Northing",0],
> > PARAMETER["Central_Meridian",-79],
> > PARAMETER["Standard_Parallel_1",34.33333333333334],
> > PARAMETER["Standard_Parallel_2",36.16666666666666],
> > PARAMETER["Latitude_Of_Origin",33.75],
> > UNIT["Meter",1]]
> > `r.in.lidar -p` in both 7.2 and trunk gives:
> > +proj=lcc +lat_1=34.33333333333334 +lat_2=36.16666666666666
+lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0 +datum=NAD83 +units=m +no_defs
> > `g.proj -p` gives the following in 7.2 and trunk in locations created
by 7.2 and trunk:
> > -PROJ_INFO-------------------------------------------------
> > name : NAD83(HARN) / North Carolina
> > datum : nad83harn
> > ellps : grs80
> > proj : lcc
> > lat_1 : 36.16666666666666
> > lat_2 : 34.33333333333334
> > lat_0 : 33.75
> > lon_0 : -79
> > x_0 : 609601.22
> > y_0 : 0
> > no_defs : defined
> > -PROJ_EPSG-------------------------------------------------
> > epsg : 3358
> > -PROJ_UNITS------------------------------------------------
> > unit : meter
> > units : meters
> > meters : 1
> > I don't know how to resolve it besides using -o but I don't know how to
justify it and why there is a difference (I don't see it in the recent
proj-related commits).
> > Thank you,
> > Vaclav
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171110/e7f4febc/attachment-0001.html>
