[GRASS-dev] [GRASS GIS] #3429: g.gui.iclass: segfault when loading vector layer
GRASS GIS trac at osgeo.org
Fri Nov 10 11:31:55 PST 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  g.gui.iclass import segfault
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 Replying to [comment:1 mlennert]:
 > Replying to [ticket:3429 mlennert]:
 > > * define group
 > > * define classes
 > > * digitize a few training areas
 > > * save training areas to vector map
 > > * close g.gui.iclass
 > > * reopen g.gui.iclass
 > > * import saved vector maps
 > > => segfault
 > I still have this problem. Can anyone reproduce ? Does anyone have a
 hint on how to debug this ?
 Yes, I looked at it couple days ago, and I could see where the problem is,
 but I didn't have time to fix it. The problem is somewhere in
 iclass/frame, how it calls the C functions, but I need to explore it more.
 The simplest way to debug this (for me) is using debugger integrated into
 qtcreator (you need to import grass as a project there). First you run
 g.gui.iclass, then in qtcreator you attach this external process and then
 do the actions in gui and the debugger shows you the place where it
 crashes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3429#comment:2>
