[GRASS-dev] [GRASS GIS] #3429: g.gui.iclass: segfault when loading vector layer
trac at osgeo.org
Sat Nov 11 10:25:50 PST 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: g.gui.iclass import segfault
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:2 annakrat]:
> Replying to [comment:1 mlennert]:
> > Replying to [ticket:3429 mlennert]:
> > > * define group
> > > * define classes
> > > * digitize a few training areas
> > > * save training areas to vector map
> > > * close g.gui.iclass
> > > * reopen g.gui.iclass
> > > * import saved vector maps
> > > => segfault
> > I still have this problem. Can anyone reproduce ? Does anyone have a
hint on how to debug this ?
> Yes, I looked at it couple days ago, and I could see where the problem
is, but I didn't have time to fix it. The problem is somewhere in
iclass/frame, how it calls the C functions, but I need to explore it more.
The simplest way to debug this (for me) is using debugger integrated into
qtcreator (you need to import grass as a project there). First you run
g.gui.iclass, then in qtcreator you attach this external process and then
do the actions in gui and the debugger shows you the place where it
crashes.
Thanks for the hint, but I have been pulling my hair out trying to make
this work. On my machine, as soon as I attach to the process, the
g.gui.iclass window blanks out completely and I cannot do anything. As
soon as I detach the debugger from the process, I can again see the GUI
window as expected and work with it. This makes it difficult to "do the
action"...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3429#comment:3>
