[GRASS-dev] [GRASS GIS] #3429: g.gui.iclass: segfault when loading vector layer
GRASS GIS trac at osgeo.org
Sat Nov 11 11:38:20 PST 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  g.gui.iclass import segfault
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 I have just been looking at this, but since I have to leave right now,
 this is where I got. I don't understand how the temporary maps work, so
 it's hard to say what consequences this has, but please test.
 Index: Vlib/open.c
 --- Vlib/open.c (revision 71523)
 +++ Vlib/open.c (working copy)
 @@ -960,7 +960,7 @@
      G_debug(1, "Vect_open_tmp_new(): name = '%s' with_z = %d", name,
 with_z);
 -    return open_new(Map, tmp_name, with_z, TEMPORARY_MAP); /* temporary
 map */
 +    return open_new(Map, tmp_name, with_z, TEMPORARY_MAP_ENV); /*
 temporary map */
 Index: gui/wxpython/iclass/frame.py
 --- gui/wxpython/iclass/frame.py        (revision 71523)
 +++ gui/wxpython/iclass/frame.py        (working copy)
 @@ -624,7 +624,8 @@
              return
          # copy features to the temporary map
 -        vname = self._getTempVectorName()
 +        #vname = self._getTempVectorName()
 +        vname = self.trainingAreaVector
          # avoid deleting temporary map
          os.environ['GRASS_VECTOR_TEMPORARY'] = '1'
          if digitClass.CopyMap(vname, tmp=True) == -1:
 For the debugging, you need to (after attaching the process) press
 Continue to release the gui, then do things in gui and it then jumps in
 qtcreator to segfaults or breakpoints.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3429#comment:4>
