[GRASS-dev] winGRASS not built/broken
Markus Metz
markus.metz.giswork at gmail.com
Sat Nov 11 08:44:18 PST 2017
On Sat, Nov 11, 2017 at 4:25 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> it seems there is an issue with winGRASS:
> 32 bit:
> https://wingrass.fsv.cvut.cz/grass73/x86/logs/log-r71641-1/error.log
> GRASS GIS 7.3.svn r71641 compilation log
> Started compilation: Tue Nov 7 21:30:33 2017
> Errors in:
> /c/msys32/usr/src/grass_trunk/raster/r.in.gdal
The error is:
main.c:345: undefined reference to `GDALSetCacheMax64 at 4'
strange, GDALSetCacheMax64 should exist on 32 bit Windows, even if "the
maximum amount of memory that can be addressed by a process might be 2 GB
or 3 GB, depending on the operating system capabilities."
Falling back to GDALSetCacheMax for MS Windows (including 64 bit Windows)
in r71677.
Markus M
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Tue Nov 7 22:05:34 2017
> 64bit:
> last build:
> WinGRASS-7.3.svn-r71641-404-Setup-x86_64.exe 08-Nov-2017 07:46
73M
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171111/59596578/attachment-0001.html>
