[GRASS-dev] [GRASS GIS] #2790: Output of t.rast.list with method=comma and columns=name does not differ from output with columns=id
trac at osgeo.org
Sun Nov 12 03:44:26 PST 2017
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.rast.list
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [ticket:2790 veroandreo]:
> Hi,
> When using t.rast.list column=name method=comma,
> both map name and mapset name are printed, so it does not differ from
asking column=id.
> GRASS 7.1.svn (latlong_wgs84):~ > t.rast.list input=precip_abs
order=start_time columns=name method=comma
prec_1 at pruebas,prec_2 at pruebas,prec_3 at pruebas,prec_4 at pruebas,prec_5 at pruebas,prec_6 at pruebas,prec_7 at pruebas,prec_8 at pruebas,prec_9 at pruebas,prec_10 at pruebas,prec_11 at pruebas,prec_12 at pruebas
order=start_time columns=id method=comma
> While several modules (r.colors, r.stats or r.series) can take this as
input, r.hants (from add-ons) gives an error
> GRASS 7.1.svn (latlong_wgs84):~ > r.hants input=`t.rast.list
input=precip_abs order=start_time columns=name method=comma` nf=2
> base_period=6 fet=10 suffix=_hants
> ERROR: Raster map <prec_1 at pruebas_hants> is not in the current mapset
> (pruebas)
The fully qualified input names where used to construct output names.
Fixed for both r.hants and r.series.lwr in r71682.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2790#comment:6>
