[GRASS-dev] [GRASS GIS] #2790: Output of t.rast.list with method=comma and columns=name does not differ from output with columns=id
GRASS GIS trac at osgeo.org
Sun Nov 12 04:14:03 PST 2017
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.0.6
 Component:  Temporal    |    Version:  svn-trunk
Resolution:              |   Keywords:  t.rast.list
       CPU:  x86-64      |   Platform:  Linux
Comment (by veroandreo):
 Thanks for the fix! I tested both r.hants and r.series.lwr and all goes
 fine.
 I keep this one open, because the output of G7:t.rast.list using
 column=name or column=id with method=comma gives the same output
 mapname at mapset, while it should be only the map name when column=name is
 used.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2790#comment:7>
