[GRASS-dev] [GRASS GIS] #3438: v.buffer silently ignores options depending on buffering alhorithm in use
trac at osgeo.org
Sun Nov 12 14:11:43 PST 2017
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.buffer, GEOS
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3438 marisn]:
> At the moment user gets no warning if some of his input parameters (i.e.
minordistance, angle) are ignored due to use of GEOS instead of native
buffering algorithm. v.buffer should fail with a fatal error if user has
provided unsupported input parameters.
v.buffer prints now (trunk r71724) warnings if options are used that apply
only to the native, deprecated algorithm. The manual is updated
accordingly.
> Current approach of setting environmental variable to switch between
GEOS and native algorithms is also suboptimal, as setting env on GNU/Linux
is easy and common, while setting on Windows is uncommon thus hard. A flag
would be better approach.
This is by purpose to make it difficult to use the buggy native algorithm.
The mechanism with an environmental variable exists only in case someone
wants to fix and test the native algorithm.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3438#comment:2>
