[GRASS-dev] Landsat MTL files
Nikos Alexandris
nik at nikosalexandris.net
Mon Nov 13 16:24:28 PST 2017
* Nikos Alexandris <nik at nikosalexandris.net> [2017-10-15 17:57:30 +0200]:
> ...in improving https://github.com/NikosAlexandris/i.landsat.import
The script will import scenes in independent Mapsets. This is contra to
the "convention" to import data (first) in the PERMANENT Mapset. If
there is interest, please see Stefan's valid comments at
https://github.com/NikosAlexandris/i.landsat.import/issues/2.
If such a script will land in the addons repository, it should be in
line with GRASS' best practices.
Thank you, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171114/c385ddd5/attachment.sig>
