[GRASS-dev] Landsat MTL files
Markus Neteler
neteler at osgeo.org
Mon Nov 13 23:35:48 PST 2017
On Nov 14, 2017 1:24 AM, "Nikos Alexandris" <nik at nikosalexandris.net> wrote:
> * Nikos Alexandris <nik at nikosalexandris.net> [2017-10-15 17:57:30 +0200]:
>> ...in improving https://github.com/NikosAlexandris/i.landsat.import
> The script will import scenes in independent Mapsets. This is contra to
> the "convention" to import data (first) in the PERMANENT Mapset.
IMHO there is no such convention.
To use different mapsets is perfectly fine.
The PERMANENT mapset is ideal for base cartography shared with all other
mapsets.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171114/2ddabfef/attachment.html>
