[GRASS-dev] Landsat MTL files
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Tue Nov 14 00:22:30 PST 2017
Sorry if I confuse something here or cause confusion...
I do understand that it can be handy to handle Landsat scenes in different mapsets. And creating new mapsets at import can be a smart workflow indeed.
I just thought GRASS modules were supposed not to write data to other mapsets than the ones they are called from (which I understood was e.g. why Sören changed modules of the temporal framework that always wrote to TGIS DB in PERMANENT)?
Cheers
Stefan
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Markus Neteler
Sent: tirsdag 14. november 2017 08.36
To: Nikos Alexandris <nik at nikosalexandris.net>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] Landsat MTL files
On Nov 14, 2017 1:24 AM, "Nikos Alexandris" <nik at nikosalexandris.net<mailto:nik at nikosalexandris.net>> wrote:
> * Nikos Alexandris <nik at nikosalexandris.net<mailto:nik at nikosalexandris.net>> [2017-10-15 17:57:30 +0200]:
>> ...in improving https://github.com/NikosAlexandris/i.landsat.import
> The script will import scenes in independent Mapsets. This is contra to
> the "convention" to import data (first) in the PERMANENT Mapset.
IMHO there is no such convention.
To use different mapsets is perfectly fine.
The PERMANENT mapset is ideal for base cartography shared with all other mapsets.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171114/04f38f94/attachment-0001.html>
