[GRASS-dev] references for v.voronoi
Anna Petrášová kratochanna at gmail.com
Sun Oct 1 13:51:21 PDT 2017
OK, thanks for the info!
On Sun, Oct 1, 2017 at 4:06 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> Hi Anna,
> On Sun, Oct 1, 2017 at 4:06 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> Hi,
>> we were just reviewing materials for class where we use v.voronoi, and
>> it has some fairly new functionality Markus added, which is not quite
>> covered in references.
> I guess you refer to the new -a and -s flags. These are not based on any
> references. The idea for these new flags came from studying v.voronoi and
> its outputs. These flags (particularly -s) are still somewhat experimental
> because v.voronoi itself is numerically a bit unstable, sometimes creating
> artefacts when input points/vertices are very close to each other. The
> reference for the basic voronoi algorithm is in the manual. The -a and -s
> flags are an example what else you can do with that algorithm.
> Markus M
>> It would be great if anyone could suggest some
>> relevant articles for the algorithm or applications? I would be happy
>> to add them there.
>> Thank you,
>> Anna
