[GRASS-dev] How to develop on windows.
CM Reddy chalamcharla at hotmail.com
Sun Oct 1 23:09:39 PDT 2017
Hi Moritz
I did the steps mentioned in the following and compiled the code successfully on Windows 10 machine.
  *   https://trac.osgeo.org/grass/wiki/CompileOnWindows
No errors in the error.log file. It created grass executable successfully.
Found following error in running the grass executable.
<error>
C:\OSGeo4W64\bin>grass73svn.bat
'""' is not recognized as an internal or external command,
operable program or batch file.
Press any key to continue . . .
</error>
Please help me in resoling the above issue.
- Thanks in advance.
CM
On 25-09-2017 23:08, Moritz Lennert wrote:
On 25/09/17 19:00, CM Reddy wrote:
Hi All,
We would like compile and install the Grass source on Windows 10
machine. Is it possible to set up the environment on Windows 10 and
develop some modules ?
   If so, please provide the steps to setup on windows machine ? Do we
need to have any specific IDE for development( like eclipse etc )?
No special IDE needed. Start with the info at [1] and come back to us if you have any questions.
Moritz
[1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171002/b3db4b81/attachment.html>
