[GRASS-dev] How to develop on windows.
Helmut Kudrnovsky
hellik at web.de
Mon Oct 2 00:49:53 PDT 2017
CM Reddy wrote
> Hi Moritz
> I did the steps mentioned in the following and compiled the code
> successfully on Windows 10 machine.
> * https://trac.osgeo.org/grass/wiki/CompileOnWindows
> No errors in the error.log file. It created grass executable successfully.
> Found following error in running the grass executable.
> <error>
> C:\OSGeo4W64\bin>grass73svn.bat
> '""' is not recognized as an internal or external command,
> operable program or batch file.
> Press any key to continue . . .
> </error>
> Please help me in resoling the above issue.
> - Thanks in advance.
> CM
> On 25-09-2017 23:08, Moritz Lennert wrote:
> On 25/09/17 19:00, CM Reddy wrote:
> Hi All,
> We would like compile and install the Grass source on Windows 10
> machine. Is it possible to set up the environment on Windows 10 and
> develop some modules ?
> If so, please provide the steps to setup on windows machine ? Do we
> need to have any specific IDE for development( like eclipse etc )?
> No special IDE needed. Start with the info at [1] and come back to us if
> you have any questions.
> Moritz
> [1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
> grass-dev mailing list
> grass-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Please post the content of
How did you invoked it?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
