[GRASS-dev] Which are the strds 'columns'?
Veronica Andreo veroandreo at gmail.com
Sat Oct 21 06:01:14 PDT 2017
Hi Nikos,
the columns that you use in the where condition of temporal modules are
those in the SQLite table that stores metadata about each map in the
st(r)ds: min, max, start_time, end_time. AFAIK, there's no metadata for the
mean, i.e. no column in the SQLite table containing that info. Here there
are some examples with t.rast.list [1] using where. Maybe the error message
could be improved as to specify which columns are available.
If, from the output t.rast.univar (with or without -e) you want to get
those maps where LST mean is higher than 10, then you would need a
different procedure. What I did eventually, was import the .txt file into
R, and there, make queries with sqldf package. There's for sure other much
better options that I would love to learn.
hth,
Vero
[1]
https://grasswiki.osgeo.org/wiki/Temporal_data_processing#Listing_maps_and_selections
2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> Shouldn't the following work?
> t.rast.univar lst where="mean > 10"
> sqlite3.OperationalError: no such column: mean
> 'min', 'max' and 'start_time' work.
> Where are the "columns"?
> Isn't the whole of what t.rast.univar -e reports supported?
> Thank you, Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171021/88f4baf9/attachment.html>
