[GRASS-dev] Which are the strds 'columns'?
Nikos Alexandris
nik at nikosalexandris.net
Sat Oct 21 08:04:40 PDT 2017
Awesome explanation, as usual!
Much appreciated.
Nikos
* Veronica Andreo <veroandreo at gmail.com> [2017-10-21 15:01:14 +0200]:
>Hi Nikos,
>the columns that you use in the where condition of temporal modules are
>those in the SQLite table that stores metadata about each map in the
>st(r)ds: min, max, start_time, end_time. AFAIK, there's no metadata for the
>mean, i.e. no column in the SQLite table containing that info. Here there
>are some examples with t.rast.list [1] using where. Maybe the error message
>could be improved as to specify which columns are available.
>If, from the output t.rast.univar (with or without -e) you want to get
>those maps where LST mean is higher than 10, then you would need a
>different procedure. What I did eventually, was import the .txt file into
>R, and there, make queries with sqldf package. There's for sure other much
>better options that I would love to learn.
>hth,
>Vero
>[1]
>https://grasswiki.osgeo.org/wiki/Temporal_data_processing#Listing_maps_and_selections
>2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
>> Shouldn't the following work?
>> t.rast.univar lst where="mean > 10"
>> sqlite3.OperationalError: no such column: mean
>> 'min', 'max' and 'start_time' work.
>> Where are the "columns"?
>> Isn't the whole of what t.rast.univar -e reports supported?
>> Thank you, Nikos
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171021/20af0ebf/attachment.sig>
