[GRASS-dev] Which are the strds 'columns'?
Veronica Andreo
veroandreo at gmail.com
Sat Oct 21 06:06:56 PDT 2017
Thanks, Soeren :)
2017-10-21 15:05 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi,
> the column option of:
> `t.rast.list --help`
> will show all columns that are available for time-stamped raster layer
> SQL selection operations.
> Best regards
> Sören
> 2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> > Shouldn't the following work?
> > t.rast.univar lst where="mean > 10"
> > sqlite3.OperationalError: no such column: mean
> > 'min', 'max' and 'start_time' work.
> > Where are the "columns"?
> > Isn't the whole of what t.rast.univar -e reports supported?
> > Thank you, Nikos
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171021/521e37a6/attachment-0001.html>
