[GRASS-dev] Which are the strds 'columns'?
Nikos Alexandris nik at nikosalexandris.net
Sat Oct 21 08:05:51 PDT 2017
Maybe add this info (part of how Vero explained as well) in
t.rast.univar?
Danke Soeren, Nikos
* Sören Gebbert <soerengebbert at googlemail.com> [2017-10-21 15:05:24 +0200]:
>Hi,
>the column option of:
>`t.rast.list --help`
>will show all columns that are available for time-stamped raster layer
>SQL selection operations.
>Best regards
>Sören
>2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
>> Shouldn't the following work?
>> t.rast.univar lst where="mean > 10"
>> sqlite3.OperationalError: no such column: mean
>> 'min', 'max' and 'start_time' work.
>> Where are the "columns"?
>> Isn't the whole of what t.rast.univar -e reports supported?
>> Thank you, Nikos
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171021/43b48953/attachment.sig>
