[GRASS-dev] Which are the strds 'columns'?
Sören Gebbert soerengebbert at googlemail.com
Sat Oct 21 12:15:18 PDT 2017
to do it coherently: all t.* modules with a where option should
mention this. Feel free to perform the necessary  manpage updates. :)
Best regards
Sören
2017-10-21 17:05 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> Maybe add this info (part of how Vero explained as well) in
> t.rast.univar?
> Danke Soeren, Nikos
> * Sören Gebbert <soerengebbert at googlemail.com> [2017-10-21 15:05:24 +0200]:
>> Hi,
>> the column option of:
>> `t.rast.list --help`
>> will show all columns that are available for time-stamped raster layer
>> SQL selection operations.
>> Best regards
>> Sören
>> 2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
>>> Shouldn't the following work?
>>> t.rast.univar lst where="mean > 10"
>>> sqlite3.OperationalError: no such column: mean
>>> 'min', 'max' and 'start_time' work.
>>> Where are the "columns"?
>>> Isn't the whole of what t.rast.univar -e reports supported?
>>> Thank you, Nikos
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> Nikos Alexandris | Remote Sensing & Geomatics
> GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
