[GRASS-dev] Which are the strds 'columns'?
Veronica Andreo
veroandreo at gmail.com
Sun Oct 22 04:18:09 PDT 2017
I added a note in the wiki [0] and I will add similar note(s) in [1]
because, as Soeren said, it is common to all t.* modules with where option.
I will think how to add some note in each manual with a where option.
cheers,
Vero
[0]
https://grasswiki.osgeo.org/wiki/Temporal_data_processing#Listing_maps_and_selections
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/temporal/temporalintro.html
2017-10-21 21:15 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi,
> to do it coherently: all t.* modules with a where option should
> mention this. Feel free to perform the necessary manpage updates. :)
> Best regards
> Sören
> 2017-10-21 17:05 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> > Maybe add this info (part of how Vero explained as well) in
> > t.rast.univar?
> > Danke Soeren, Nikos
> > * Sören Gebbert <soerengebbert at googlemail.com> [2017-10-21 15:05:24
> +0200]:
> >> Hi,
> >> the column option of:
> >> `t.rast.list --help`
> >> will show all columns that are available for time-stamped raster layer
> >> SQL selection operations.
> >> Best regards
> >> Sören
> >> 2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> >>> Shouldn't the following work?
> >>> t.rast.univar lst where="mean > 10"
> >>> sqlite3.OperationalError: no such column: mean
> >>> 'min', 'max' and 'start_time' work.
> >>> Where are the "columns"?
> >>> Isn't the whole of what t.rast.univar -e reports supported?
> >>> Thank you, Nikos
> >>> _______________________________________________
> >>> grass-dev mailing list
> >>> grass-dev at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> > Nikos Alexandris | Remote Sensing & Geomatics
> > GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171022/524a90a9/attachment-0001.html>
