[GRASS-dev] [GRASS GIS] #3430: v.clean threshold in lat-long: metric or not?
GRASS GIS trac at osgeo.org
Sun Oct 22 23:37:35 PDT 2017
 Reporter:  neteler      |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.2.3
Component:  Vector       |    Version:  7.2.2
 Keywords:  v.clean      |        CPU:  Unspecified
 Platform:  Unspecified  |
 https://gis.stackexchange.com/questions/258089/v-clean-with-rmarea-and-
 lat-long-projection
 There is some confusion concerning this message:
 main.c:
     /* TODO: threshold might be recalculated with optional geodesic
 support to meters */
     if (G_projection() == PROJECTION_LL)
         G_important_message(_("Note: In latitude-longitude coordinate
 system specify threshold in degree unit"));
 while the documentation reads:
 grep meter v.clean.html
 case, also the threshold parameter requires several values to be listed
 Threshold must always be in square meters, also for latitude-longitude
 locations or locations with units other than meters.
 Should the G_important_message() be removed from main.c?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3430>
