[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
GRASS GIS trac at osgeo.org
Mon Oct 23 13:19:07 PDT 2017
  Reporter:  jachym       |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 I have fixed the parameter order and a missing "_" in args.c and uploaded
 under the same        "shp-geopackage.4.patch​" name (please use that to
 continue).
 But it does not compile for me:
 args.c: In function ‘parse_args’:
 args.c:36:5: error: ‘tempDriver’ undeclared (first use in this function);
 did you mean ‘dbDriver’?
      tempDriver = OGRGetDriverByName("GPKG");
      dbDriver
 args.c:36:5: note: each undeclared identifier is reported only once for
 each function it appears in
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:11>
