[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
trac at osgeo.org
Mon Oct 23 13:30:07 PDT 2017
Reporter: jachym | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
args.c:
tempDriver = OGRGetDriverByName("GPKG");
I found a hint:
http://www.gdal.org/ogr__api_8h.html#ae814db7e2212b9bbb0fd8c361bee11fe
"Fetch the indicated driver.
NOTE: Starting with GDAL 2.0, it is NOT safe to cast the returned handle
to OGRSFDriver*. If a C++ object is needed, the handle should be cast to
GDALDriver*.
Deprecated: Use GDALGetDriverByName() in GDAL 2.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:12>
