[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
trac at osgeo.org
Mon Oct 23 14:41:46 PDT 2017
Reporter: jachym | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:16 rouault]:
> Oh wait, the reason might be much more mundain (deduced from code
review, no actual testing). Apparently OGRRegisterAll() is called by
OGR_list_write_drivers(), which is called after this new code... So no
driver is available when it is called. Fix: call OGRRegisterAll() much
earlier
Bingo! I moved it up, patch updated. Now "GPKG" shows up as a default (I'm
on Fedora with GDAL 2.x) :-)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:17>
