[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
GRASS GIS trac at osgeo.org
Mon Oct 23 14:32:48 PDT 2017
  Reporter:  jachym       |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by rouault):
 Oh wait, the reason might be much more mundain (deduced from code review,
 no actual testing). Apparently OGRRegisterAll() is called by
 OGR_list_write_drivers(), which is called after this new code... So no
 driver is available when it is called. Fix: call OGRRegisterAll() much
 earlier
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:16>
