[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
GRASS GIS trac at osgeo.org
Mon Oct 23 14:25:57 PDT 2017
  Reporter:  jachym       |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by rouault):
 GDALGetDriverByName() can only be used to detect vector drivers since GDAL
 2.0. Previously you had to use OGRGetDriverByName() (OGRGetDriverByName()
 can still be used in GDAL 2.x)
 @neteler Are you using GDAL < 1.11, or perhaps a GDAL build without
 sqlite3 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:15>
