[GRASS-dev] [GRASS GIS] #3414: v.import: ERROR: Invalid e-w resolution field: 0 when importing EU_LAEA point into Sinusoidal location
GRASS GIS trac at osgeo.org
Thu Sep 7 13:09:10 PDT 2017
  Reporter:  neteler             |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:  7.2.2
 Component:  Projections/Datums  |    Version:  svn-trunk
Resolution:                      |   Keywords:  v.import
       CPU:  Unspecified         |   Platform:  Linux
Comment (by mmetz):
 Replying to [comment:12 neteler]:
 > Replying to [comment:10 mmetz]:
 > > For v.in.ogr, some more changes are needed, see attached patch
 no_vector_default_region_2.diff (the patch also solves some TODOs).
 > I get a compilation error:
 Oops, fixed in the updated attached patch no_vector_default_region_2.diff.
 About backporting: v.in.ogr in trunk is already quite different from
 relbr72, and with this patch, it would be more different. IMHO, the fix
 for OSM import and this fix are both bug fixes, i.e. once confirmed
 working, patched v.in.ogr in trunk should be backported as is to relbr72.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3414#comment:13>
