[GRASS-dev] [GRASS GIS] #3414: v.import: ERROR: Invalid e-w resolution field: 0 when importing EU_LAEA point into Sinusoidal location
GRASS GIS trac at osgeo.org
Thu Sep 7 13:26:40 PDT 2017
  Reporter:  neteler             |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:  7.2.2
 Component:  Projections/Datums  |    Version:  svn-trunk
Resolution:                      |   Keywords:  v.import
       CPU:  Unspecified         |   Platform:  Linux
Comment (by neteler):
 Thanks for the new updated  no_vector_default_region_2.diff, tested here:
 GRASS 7.3.svn (modis_sinusoidal):~ > v.import --v in=~/point_eu_laea.shp
 out=point_eu_laea2Creating temporary location for
 </home/mundialis/point_eu_laea.shp>...
 Using OGR driver 'ESRI Shapefile'
 Projection of dataset does not appear to match current location.
 GRASS LOCATION PROJ_INFO is:
 a: 6371007.181
 es: 0
 proj: sinu
 lon_0: 0
 x_0: 0
 y_0: 0
 no_defs: defined
 Import dataset PROJ_INFO is:
 datum: etrs89
 ellps: grs80
 proj: laea
 lat_0: 52
 lon_0: 10
 x_0: 4321000
 y_0: 3210000
 no_defs: defined
 In case of no significant differences in the projection definitions, use
 the -o flag to ignore them and use current location definition.
 Consider generating a new location with 'location' parameter from input
 data set.
 switch to temp location
 -PROJ_INFO-------------------------------------------------
 datum : etrs89
 ellps : grs80
 proj : laea
 lat_0 : 52
 lon_0 : 10
 x_0 : 4321000
 y_0 : 3210000
 no_defs : defined
 -PROJ_UNITS------------------------------------------------
 unit : Meter
 units : Meters
 meters : 1
 Importing </home/mundialis/point_eu_laea.shp> ...
 Projection of input dataset and current location appear to match
 Check if OGR layer <point_eu_laea> contains polygons...
  100%
 Importing 1 features
 Using native format
 Default driver / database set to:
 driver: sqlite
 database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
 Column name <cat> renamed to <cat_>
 Importing 1 features (OGR layer <point_eu_laea>)...
  100%
 Building topology for vector map <point_eu_laea2 at PERMANENT>...
 Registering primitives...
 One primitive registered
 One vertex registered
 Building areas...
  100%
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
  100%
 Topology was built
 Number of nodes: 0
 Number of primitives: 1
 Number of points: 1
 Number of lines: 0
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 Reprojecting <point_eu_laea2>...
 Input Projection Parameters:  +proj=laea +lat_0=52 +lon_0=10 +x_0=4321000
 +y_0=3210000 +no_defs +a=6378137 +rf=298.257222101
 +towgs84=0.000,0.000,0.000
 Input Unit Factor: 1
 Output Projection Parameters:  +proj=sinu +lon_0=0 +x_0=0 +y_0=0 +no_defs
 +a=6371007.181 +b=6371007.181
 Output Unit Factor: 1
 Using native format
 Reprojecting primitives ...
 <point_eu_laea2 at Germany_LST_1km_daily_gdd_2016>...
 Building areas...
  100%
 0 areas built
 0 isles built
  100%
 Topology was built
 Number of nodes: 0
 Number of points: 1
 Number of lines: 0
 Number of areas: 0
 Number of isles: 0
 Now the file is smoothly imported :-)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3414#comment:14>
