[GRASS-dev] [GRASS-SVN] r71471 - grass/trunk/locale/po
Veronica Andreo veroandreo at gmail.com
Sun Sep 10 08:41:40 PDT 2017
2017-09-06 21:24 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Wed, Sep 6, 2017 at 9:03 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
> > No, but will do immediately. I wanted to make sure it's in the tree
> before
> > the release is tagged.
> ok fine.
> > So, we should not touch po files in the source tree anymore ?
> Yes, we translate in transifex and then (still manually) merge into
> the source code. I did that recently.
> From what I understood (Luca knows best) I described the procedure here:
> https://trac.osgeo.org/grass/browser/grass/trunk/locale/README#L116
> TODO: make the merge-back into trunk and relbranch72 a cronjob on the
> grass.osgeo.org server.
> Yet I had to do several manual cleanups after the merge, so probably a
> cronjob is impossible.
just out of curiosity... what kind of cleanups? Is there anything we could
do when translating to avoid those cleanups afterwards?
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170910/e7facd60/attachment.html>
