[GRASS-dev] [GRASS-SVN] r71471 - grass/trunk/locale/po
Luca Delucchi
lucadeluge at gmail.com
Mon Sep 11 23:49:55 PDT 2017
On 10 September 2017 at 18:11, Markus Neteler <neteler at osgeo.org> wrote:
> For example,
> - disconnected (i.e. unused) translations accumulate at the end of the
> .po files. This needs to be trimmed from time to time. There is a
> gettext tool for that but it doesn't seem to have much effect
> - if a new language is initiated on transifex, several .po file header
> lines are not populated properly. To be fixed manually or some
> advanced "sed" magic
> - "make verify" reveils errors which need to be manually fixed.
> Not sure how to address these issues in a scripted way.
could we check with other projects like QGIS or ZOO?
> Markus
ciao
Luca
www.lucadelu.org
