[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Vincent Bain
bain at toraval.fr
Wed Sep 20 00:06:16 PDT 2017
Hi Helmut,
don't know if you finally found the reason of the warning message you
mentioned back in july. On a freshly built Debian stretch virtual
machine I have the same issue today :
** (wxgui.py:5023): WARNING **: invalid source position for vertical
gradient
I guess it is not a fatal issue as GRASS seems to work nicely despite
this error.
Best,
Vincent.
Le samedi 08 juillet 2017 à 12:01 -0700, Helmut Kudrnovsky a écrit :
> just a fresh compiled
> GRASS version: 7.3.svn
> GRASS SVN revision: r71243
> Build date: 2017-07-08
> Build platform: x86_64-pc-linux-gnu
> GDAL: 2.2.0
> PROJ.4: 4.9.3
> GEOS: 3.5.1
> SQLite: 3.16.2
> Python: 2.7.13
> wxPython: 3.0.2.0
> Platform: Linux-4.9.0-3-amd64-x86_64-with-debian-9.0
> I get following messages during GUI startup
> GRASS 7.3.svn
> (nc_spm_08_grass7):~/dev/cpp/grass7_trunk/bin.x86_64-pc-linux-gnu >
> gradient
> gradient
> gradient
> gradient
> any idea? or just ignoring?
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/wxgui-py-19192-WARNING-invalid-source-position-for-vertical-gradient-tp5327115.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
