[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Anna Petrášová kratochanna at gmail.com
Wed Sep 20 04:06:36 PDT 2017
You would need to isolate which part of the GUI is responsible for it,
otherwise there is too many options to guess. If this started recently,
maybe you can isolate the commit, that would help too.
Anna
On Sep 20, 2017 4:59 AM, "Vincent Bain" <bain at toraval.fr> wrote:
> Thank you Markus for your suggestion,
> unfortunately I don't have any idea where to find the relevant piece of
> code implied.
> Vincent.
> Le mercredi 20 septembre 2017 à 10:23 +0200, Markus Neteler a écrit :
> > On Wed, Sep 20, 2017 at 9:06 AM, Vincent Bain <bain at toraval.fr> wrote:
> > > Hi Helmut,
> > > don't know if you finally found the reason of the warning message you
> > > mentioned back in july. On a freshly built Debian stretch virtual
> > > machine I have the same issue today :
> > > ** (wxgui.py:5023): WARNING **: invalid source position for vertical
> > > gradient
> > > I guess it is not a fatal issue as GRASS seems to work nicely despite
> > > this error.
> > Searching the error in internet I found a similar one:
> > ** (thunar:2530): WARNING **: invalid source position for vertical
> gradient
> > https://github.com/lassekongo83/zuki-themes/issues/104
> > Fix:
> > https://github.com/lassekongo83/zuki-themes/commit/
> 318efd3a83f6305414f58b9dca417072c16e5ef6
> > Maybe something like this could be applied also here?
> > Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170920/b5de031f/attachment.html>
