[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Vincent Bain
bain at toraval.fr
Wed Sep 20 05:01:11 PDT 2017
Thank you Anna for your reply,
the messages pops up in the terminal when I interact with the layer
manager window like : swithching between thumbnail, resizing window,
confirming deletion of a map).
after digging it a little bit deeper, I guess it has rather something to
do with the environment : I currently work on different debian machines;
the issue happens when I build the latest trunk version (r:71500) on a
new/clean debian 9 (stretch). Building the same release on my old debian
8 works fine.
I have several concurrent python versions on my old machine I switch
with update-alternative, but I am not sure about which version GRASS is
built against on each machine...
Vincent.
Le mercredi 20 septembre 2017 à 07:06 -0400, Anna Petrášová a écrit :
> You would need to isolate which part of the GUI is responsible for it,
> otherwise there is too many options to guess. If this started
> recently, maybe you can isolate the commit, that would help too.
> Anna
> On Sep 20, 2017 4:59 AM, "Vincent Bain" <bain at toraval.fr> wrote:
> Thank you Markus for your suggestion,
> unfortunately I don't have any idea where to find the relevant
> piece of
> code implied.
> Vincent.
> Le mercredi 20 septembre 2017 à 10:23 +0200, Markus Neteler a
> écrit :
> > On Wed, Sep 20, 2017 at 9:06 AM, Vincent Bain
> > > Hi Helmut,
> > > don't know if you finally found the reason of the warning
> message you
> > > mentioned back in july. On a freshly built Debian stretch
> virtual
> > > machine I have the same issue today :
> > > ** (wxgui.py:5023): WARNING **: invalid source position
> for vertical
> > > gradient
> > > I guess it is not a fatal issue as GRASS seems to work
> nicely despite
> > > this error.
> > Searching the error in internet I found a similar one:
> > ** (thunar:2530): WARNING **: invalid source position for
> vertical gradient
> > https://github.com/lassekongo83/zuki-themes/issues/104
> > Fix:
> https://github.com/lassekongo83/zuki-themes/commit/318efd3a83f6305414f58b9dca417072c16e5ef6
> > Maybe something like this could be applied also here?
> > Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
