[GRASS-dev] [GRASS-SVN] r72590 - grass/trunk/general/g.region
Martin Landa landa.martin at gmail.com
Thu Apr 5 04:01:04 PDT 2018
2018-04-05 12:16 GMT+02:00  <svn_grass at osgeo.org>:
> Author: jachym
> Date: 2018-04-05 03:16:14 -0700 (Thu, 05 Apr 2018)
> New Revision: 72590
> Modified:
>    grass/trunk/general/g.region/local_proto.h
>    grass/trunk/general/g.region/main.c
> Log:
> Adding -L flag to g.region for getting list of regions
1) upper-case flags should not be used
2) this functionality is already available as `g.list type=region` if
I understand well
3) I would prefer to see ticket with related discussion before
committing change into trunk
Consider reverting this change. g.list functionality is not suitable
for your need?
Thanks for clarification, Martin
> Modified: grass/trunk/general/g.region/local_proto.h
> --- grass/trunk/general/g.region/local_proto.h  2018-04-03 10:43:37 UTC (rev 72589)
> +++ grass/trunk/general/g.region/local_proto.h  2018-04-05 10:16:14 UTC (rev 72590)
> @@ -12,6 +12,7 @@
>  #define PRINT_NANGLE 0x100
>  #define PRINT_GMT    0x200
>  #define PRINT_WMS    0x400
> +#define PRINT_WF     0x800
>  /* zoom.c */
>  int zoom(struct Cell_head *, const char *, const char *);
> Modified: grass/trunk/general/g.region/main.c
> --- grass/trunk/general/g.region/main.c 2018-04-03 10:43:37 UTC (rev 72589)
> +++ grass/trunk/general/g.region/main.c 2018-04-05 10:16:14 UTC (rev 72590)
> @@ -13,6 +13,7 @@
>   *             Read the file COPYING that comes with GRASS for details.
> +#include <dirent.h>
>  #include <string.h>
>  #include <stdlib.h>
>  #include <math.h>
> @@ -39,8 +40,11 @@
>      const char *value;
>      const char *name;
>      const char *mapset;
> +    char *windows_path = G_malloc(1024);
>      char **rast_ptr, **vect_ptr;
>      int pix;
> +    DIR *d;
> +    struct dirent *dir;
>      struct GModule *module;
>      struct
> @@ -48,7 +52,7 @@
>         struct Flag
>             *update, *print, *gprint, *flprint, *lprint, *eprint, *nangle,
>             *center, *res_set, *dist_res, *dflt, *z, *savedefault,
> -           *bbox, *gmt_style, *wms_style;
> +           *bbox, *gmt_style, *wms_style, *list;
>      } flag;
>      struct
> @@ -165,6 +169,11 @@
>      flag.update->description = _("Do not update the current region");
>      flag.update->guisection = _("Effects");
> +    flag.list = G_define_flag();
> +    flag.list->key = 'L';
> +    flag.list->description = _("List available regions");
> +    flag.list->guisection = _("Print");
>      /* parameters */
>      parm.region = G_define_standard_option(G_OPT_M_REGION);
> @@ -362,7 +371,7 @@
>      G_option_required(flag.dflt, flag.savedefault, flag.print, flag.lprint,
>                        flag.eprint, flag.center, flag.gmt_style, flag.wms_style,
>                        flag.dist_res, flag.nangle, flag. z, flag.bbox, flag.gprint,
> -                      flag.res_set, flag.update, parm.region, parm.raster,
> +                      flag.res_set, flag.update, flag.list, parm.region, parm.raster,
>                        parm.raster3d, parm.vect, parm.north, parm.south, parm.east,
>                        parm.west, parm.top, parm.bottom, parm.rows, parm.cols,
>                        parm.res, parm.res3, parm.nsres, parm.ewres, parm.tbres,
> @@ -850,6 +859,21 @@
>      if (print_flag)
>         print_window(&window, print_flag, flat_flag);
> +    if (flag.list->answer) {
> +          mapset = G_mapset_path();
> +          sprintf(windows_path, "%s/%s", mapset, "windows");
> +          d = opendir(windows_path);
> +          if (d) {
> +            while ((dir = readdir(d)) != NULL) {
> +              if (dir->d_type == DT_REG) {
> +                printf("%s\n", dir->d_name);
> +            closedir(d);
>      exit(EXIT_SUCCESS);
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
