[GRASS-dev] [GRASS-SVN] r72590 - grass/trunk/general/g.region
Jachym Cepicky jachym.cepicky at gmail.com
Thu Apr 5 04:09:53 PDT 2018
sorry for too rush approach, you can certainly revert the commit
Jachym
čt 5. 4. 2018 v 13:01 odesílatel Martin Landa <landa.martin at gmail.com>
napsal:
> Hi,
> 2018-04-05 12:16 GMT+02:00  <svn_grass at osgeo.org>:
> > Author: jachym
> > Date: 2018-04-05 03:16:14 -0700 (Thu, 05 Apr 2018)
> > New Revision: 72590
> > Modified:
> >    grass/trunk/general/g.region/local_proto.h
> >    grass/trunk/general/g.region/main.c
> > Log:
> > Adding -L flag to g.region for getting list of regions
> 1) upper-case flags should not be used
> 2) this functionality is already available as `g.list type=region` if
> I understand well
> 3) I would prefer to see ticket with related discussion before
> committing change into trunk
> Consider reverting this change. g.list functionality is not suitable
> for your need?
> Thanks for clarification, Martin
> > Modified: grass/trunk/general/g.region/local_proto.h
> > --- grass/trunk/general/g.region/local_proto.h  2018-04-03 10:43:37 UTC
> (rev 72589)
> > +++ grass/trunk/general/g.region/local_proto.h  2018-04-05 10:16:14 UTC
> (rev 72590)
> > @@ -12,6 +12,7 @@
> >  #define PRINT_NANGLE 0x100
> >  #define PRINT_GMT    0x200
> >  #define PRINT_WMS    0x400
> > +#define PRINT_WF     0x800
> >  /* zoom.c */
> >  int zoom(struct Cell_head *, const char *, const char *);
> > Modified: grass/trunk/general/g.region/main.c
> > --- grass/trunk/general/g.region/main.c 2018-04-03 10:43:37 UTC (rev
> 72589)
> > +++ grass/trunk/general/g.region/main.c 2018-04-05 10:16:14 UTC (rev
> 72590)
> > @@ -13,6 +13,7 @@
> >   *             Read the file COPYING that comes with GRASS for details.
> > +#include <dirent.h>
> >  #include <string.h>
> >  #include <stdlib.h>
> >  #include <math.h>
> > @@ -39,8 +40,11 @@
> >      const char *value;
> >      const char *name;
> >      const char *mapset;
> > +    char *windows_path = G_malloc(1024);
> >      char **rast_ptr, **vect_ptr;
> >      int pix;
> > +    DIR *d;
> > +    struct dirent *dir;
> >      struct GModule *module;
> >      struct
> > @@ -48,7 +52,7 @@
> >         struct Flag
> >             *update, *print, *gprint, *flprint, *lprint, *eprint,
> *nangle,
> >             *center, *res_set, *dist_res, *dflt, *z, *savedefault,
> > -           *bbox, *gmt_style, *wms_style;
> > +           *bbox, *gmt_style, *wms_style, *list;
> >      } flag;
> >      struct
> > @@ -165,6 +169,11 @@
> >      flag.update->description = _("Do not update the current region");
> >      flag.update->guisection = _("Effects");
> > +    flag.list = G_define_flag();
> > +    flag.list->key = 'L';
> > +    flag.list->description = _("List available regions");
> > +    flag.list->guisection = _("Print");
> >      /* parameters */
> >      parm.region = G_define_standard_option(G_OPT_M_REGION);
> > @@ -362,7 +371,7 @@
> >      G_option_required(flag.dflt, flag.savedefault, flag.print,
> flag.lprint,
> >                        flag.eprint, flag.center, flag.gmt_style,
> flag.wms_style,
> >                        flag.dist_res, flag.nangle, flag. z, flag.bbox,
> flag.gprint,
> > -                      flag.res_set, flag.update, parm.region,
> parm.raster,
> > +                      flag.res_set, flag.update, flag.list,
> parm.region, parm.raster,
> >                        parm.raster3d, parm.vect, parm.north, parm.south,
> parm.east,
> >                        parm.west, parm.top, parm.bottom, parm.rows,
> parm.cols,
> >                        parm.res, parm.res3, parm.nsres, parm.ewres,
> parm.tbres,
> > @@ -850,6 +859,21 @@
> >      if (print_flag)
> >         print_window(&window, print_flag, flat_flag);
> > +    if (flag.list->answer) {
> > +          mapset = G_mapset_path();
> > +          sprintf(windows_path, "%s/%s", mapset, "windows");
> > +          d = opendir(windows_path);
> > +          if (d) {
> > +            while ((dir = readdir(d)) != NULL) {
> > +              if (dir->d_type == DT_REG) {
> > +                printf("%s\n", dir->d_name);
> > +            closedir(d);
> >      exit(EXIT_SUCCESS);
> > grass-commit mailing list
> > grass-commit at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-commit
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180405/182b5aa4/attachment-0001.html>
