[GRASS-dev] [GRASS-SVN] r72590 - grass/trunk/general/g.region
Markus Metz markus.metz.giswork at gmail.com
Thu Apr 5 13:57:47 PDT 2018
On Thu, Apr 5, 2018 at 1:09 PM, Jachym Cepicky <jachym.cepicky at gmail.com>
wrote:
> Hi,
> sorry for too rush approach, you can certainly revert the commit
I agree with Martin, the commit does not make sense, and you should revert
the commit yourself.
Thanks,
Markus M
> Jachym
> čt 5. 4. 2018 v 13:01 odesílatel Martin Landa <landa.martin at gmail.com>
napsal:
>> Hi,
>> 2018-04-05 12:16 GMT+02:00  <svn_grass at osgeo.org>:
>> > Author: jachym
>> > Date: 2018-04-05 03:16:14 -0700 (Thu, 05 Apr 2018)
>> > New Revision: 72590
>> > Modified:
>> >    grass/trunk/general/g.region/local_proto.h
>> >    grass/trunk/general/g.region/main.c
>> > Log:
>> > Adding -L flag to g.region for getting list of regions
>> 1) upper-case flags should not be used
>> 2) this functionality is already available as `g.list type=region` if
>> I understand well
>> 3) I would prefer to see ticket with related discussion before
>> committing change into trunk
>> Consider reverting this change. g.list functionality is not suitable
>> for your need?
>> Thanks for clarification, Martin
>> > Modified: grass/trunk/general/g.region/local_proto.h
>> > --- grass/trunk/general/g.region/local_proto.h  2018-04-03 10:43:37
UTC (rev 72589)
>> > +++ grass/trunk/general/g.region/local_proto.h  2018-04-05 10:16:14
UTC (rev 72590)
>> > @@ -12,6 +12,7 @@
>> >  #define PRINT_NANGLE 0x100
>> >  #define PRINT_GMT    0x200
>> >  #define PRINT_WMS    0x400
>> > +#define PRINT_WF     0x800
>> >  /* zoom.c */
>> >  int zoom(struct Cell_head *, const char *, const char *);
>> > Modified: grass/trunk/general/g.region/main.c
>> > --- grass/trunk/general/g.region/main.c 2018-04-03 10:43:37 UTC (rev
72589)
>> > +++ grass/trunk/general/g.region/main.c 2018-04-05 10:16:14 UTC (rev
72590)
>> > @@ -13,6 +13,7 @@
>> >   *             Read the file COPYING that comes with GRASS for
details.
>> > +#include <dirent.h>
>> >  #include <string.h>
>> >  #include <stdlib.h>
>> >  #include <math.h>
>> > @@ -39,8 +40,11 @@
>> >      const char *value;
>> >      const char *name;
>> >      const char *mapset;
>> > +    char *windows_path = G_malloc(1024);
>> >      char **rast_ptr, **vect_ptr;
>> >      int pix;
>> > +    DIR *d;
>> > +    struct dirent *dir;
>> >      struct GModule *module;
>> >      struct
>> > @@ -48,7 +52,7 @@
>> >         struct Flag
>> >             *update, *print, *gprint, *flprint, *lprint, *eprint,
*nangle,
>> >             *center, *res_set, *dist_res, *dflt, *z, *savedefault,
>> > -           *bbox, *gmt_style, *wms_style;
>> > +           *bbox, *gmt_style, *wms_style, *list;
>> >      } flag;
>> >      struct
>> > @@ -165,6 +169,11 @@
>> >      flag.update->description = _("Do not update the current region");
>> >      flag.update->guisection = _("Effects");
>> > +    flag.list = G_define_flag();
>> > +    flag.list->key = 'L';
>> > +    flag.list->description = _("List available regions");
>> > +    flag.list->guisection = _("Print");
>> >      /* parameters */
>> >      parm.region = G_define_standard_option(G_OPT_M_REGION);
>> > @@ -362,7 +371,7 @@
>> >      G_option_required(flag.dflt, flag.savedefault, flag.print,
flag.lprint,
>> >                        flag.eprint, flag.center, flag.gmt_style,
flag.wms_style,
>> >                        flag.dist_res, flag.nangle, flag. z, flag.bbox,
flag.gprint,
>> > -                      flag.res_set, flag.update, parm.region,
parm.raster,
>> > +                      flag.res_set, flag.update, flag.list,
parm.region, parm.raster,
>> >                        parm.raster3d, parm.vect, parm.north,
parm.south, parm.east,
>> >                        parm.west, parm.top, parm.bottom, parm.rows,
parm.cols,
>> >                        parm.res, parm.res3, parm.nsres, parm.ewres,
parm.tbres,
>> > @@ -850,6 +859,21 @@
>> >      if (print_flag)
>> >         print_window(&window, print_flag, flat_flag);
>> > +    if (flag.list->answer) {
>> > +          mapset = G_mapset_path();
>> > +          sprintf(windows_path, "%s/%s", mapset, "windows");
>> > +          d = opendir(windows_path);
>> > +          if (d) {
>> > +            while ((dir = readdir(d)) != NULL) {
>> > +              if (dir->d_type == DT_REG) {
>> > +                printf("%s\n", dir->d_name);
>> > +            closedir(d);
>> >      exit(EXIT_SUCCESS);
>> > _______________________________________________
>> > grass-commit mailing list
>> > grass-commit at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-commit
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180405/c76a44b6/attachment.html>
