[GRASS-dev] [gdal-dev] PROJ 5 support in trunk
Markus Metz
markus.metz.giswork at gmail.com
Sun Apr 8 13:13:36 PDT 2018
On Tue, Apr 3, 2018 at 1:57 PM, Kristian Evers <kreve at sdfe.dk> wrote:
> Markus,
> Sorry for the late reply – you mail got caught by the corporate spam
filter.
> > The challenge is that users of other software using the new PROJ API
like GDAL and GRASS expect that reprojecting a dataset from one CRS to
another CRS "just works". Input and output CRS can be anything custom
defined. Either PROJ or other software using PROJ must have some mechanism
to decide if the requested reprojection can be done or not.
> And with my proposal to change proj_create_crs_to_crs() to allow input
other than strings on the form “+init=file:key” you will get exactly what
you have always had with the old API. You can definitely argue that this
has never “just worked”, since using the WGS84 hub datum is rarely doing
the correct thing, but for most users it is good enough.
For most datasets, WGS84 as pivot datum should be good enough, considering
the limited spatial accuracy of many real-world datasets.
> This will not be the case forever though. It is my hope that eventually
we will have a system the really “just works”, even for users requiring
high accuracy, but for now we only have the basic scaffolding that
eventually will make this possible. Patience will be required :-)
FWIW, I added support for user-defined pipelines in GRASS in r.proj
(r72598) and v.proj (r72599) with a new pipeline option.
Markus M
> > Looking forward to this function! But what if a dataset comes with a
CRS definition without EPSG code? Can we expect that PROJ handles this or
should applications using the PROJ API handle this?
> Without having thought this through all the way to the end yet, I think
this situation will be possible to handle. The idea being that if you
specify an EPSG CRS on one side and a string like “+proj=merc” or whatever,
we could default to a transformation with hub datum like we do today.
Either by going from EPSG:xxxx to WGS84 (or something else that makes sense
in the situation) and then transform from the hub datum to the custom CRS.
It will be a best guess as to how to that transformation but better than
nothing, and probably correct in most cases.
> I might have overlooked something, so no promises on the final
implementation yet!
> /Kristian
> Fra: Markus Metz [mailto:markus.metz.giswork at gmail.com]
> Sendt: 27. marts 2018 21:50
> Til: Kristian Evers <kreve at sdfe.dk>
> Cc: GRASS developers list <grass-dev at lists.osgeo.org>; gdal-dev <
gdal-dev at lists.osgeo.org>
> Emne: Re: [gdal-dev] [GRASS-dev] PROJ 5 support in trunk
> On Mon, Mar 26, 2018 at 10:51 PM, Kristian Evers <kreve at sdfe.dk> wrote:
> On 26 Mar 2018, at 21:21, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> There is an important difference between the PROJ4 and the PROJ5+
API/syntax:
> The old PROJ4 API uses latlong WGS84 as pivot datum for coordinate
transformations like
> projection1 -> latlong WGS84 -> projection2
> or in '+to' syntax
> projection1 +to projection2
> The new PROJ5+ API no longer uses a pivot datum. The advantage is that
you can directly convert from one datum to another, without going through
WGS84. The disadvantage is that the user/software using the new API has to
make sure that either a common pivot datum is used or coordinates are
correctly transformed from one datum to another, e.g. with a Helmert
Transform.
> Both GDAL and GRASS have implemented the new API as a simple 2-step
pipeline like
> 1. projection1 -> some latlong
> 2. some latlong -> projection2
> or in pipeline syntax
> +proj=pipeline
> +step +inv projection1
> +step projection2
> This is actually exactly what the proj_crs_to_crs() function does. When I
originally wrote it I had an idea that this should only be used with
init-files,
> but seeing how people need a simple way to do what they’ve always done I
think it might be better to relax that requirement and allow input similar
> to what goes into cs2cs and pj_transform().
> The challenge is that users of other software using the new PROJ API like
GDAL and GRASS expect that reprojecting a dataset from one CRS to another
CRS "just works". Input and output CRS can be anything custom defined.
Either PROJ or other software using PROJ must have some mechanism to decide
> My plan for this function is that it eventually will be able to construct
a transformation between CRS’s without the WGS84 pivot. This will be guided
> by the EPSG database. I have still to work out exactly how. For now
though, it works fine with already existing init files and WGS84 as a pivot
datum.
> My hope is that this will land in version 6 but I won’t promise that just
yet.
> Looking forward to this function! But what if a dataset comes with a CRS
> Markus M
> Even Rouault has done some tests and found sometimes subtle differences
in the results between the old and new API/syntax. Further on, there is no
mechanism (yet) in place to validate the pipeline, most importantly that
the output of step 1 conforms to the required input for step 2.
> I believe we have sorted those problems out in the coming version 5.0.1.
> Regarding validation of input/output from pipeline steps. We can probably
do some basic checks, but in the end you will always be required to know
> what you are doing. Mind you, we are not expecting everyday users to
construct their own pipelines all the time. It is a powertool for the
accomplished
> user that knows what he is doing. Most users should have their needs met
by predefined transformations in init-files such as the epsg file. And
eventually
> in a more clever way using the EPSG database directly as mentioned above.
> IMHO, the implementation of the new PROJ5+ API/syntax in GDAL and GRASS
should be regarded as experimental and testing by as many people as
possible would be a huge benefit to PROJ/GDAL/GRASS and to all applications
using these projects.
> Markus M
> On Sun, Mar 25, 2018 at 10:47 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> > >Now (last related commit is trunk r72522) it's finished. I have
>introduced
> > a new GRASS API that handles both PROJ 4 and PROJ >5, consisting of
> > Thanks for this Update!
> > Fyi See
> > https://lists.osgeo.org/pipermail/osgeo4w-dev/2018-March/003557.html
> > The API from PROJ 4 lives on in PROJ 5, so GRASS 7.4 should be able to
use
> > PROJ 5 as well. We’ve been carefull not to breaking anything with this
> > release.
> > That comes with PROJ 6 and 7. Of course there might be implementation
> > details
> > in GRASS that I am unaware of that makes using PROJ 5 impossible.
> > best regards
> > Helmut
> > Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> > grass-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180408/90b4179b/attachment.html>
