[GRASS-dev] [GRASS GIS] #3548: sql where statement encoding issue on windows
trac at osgeo.org
Fri Apr 20 03:23:26 PDT 2018
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.4.1
Component: Database | Version: 7.4.0
Resolution: | Keywords: select, where, wingrass, encoding
CPU: Unspecified | Platform: Unspecified
Description changed by martinl:
Old description:
> SQL WHERE statements with diacritics on Windows return no records. It
> seems to be a bug. Same command performed in GRASS GUI (no record, wrong)
> and SQLiteBrowser (one record, correct), see
> attachment:grass_bug_windows_db_select.png. It seems to be encoding
> issue, tested with Czech Windows 8.1 localization (cp1250). Strangely,
> records with diacritics appear correct in GRASS GUI, see
> attachment:grass_bug_windows_encoding.png
New description:
and SQLiteBrowser (one record, correct). See
[[Image(grass_bug_windows_db_select.png, 500px)]].
It seems to be encoding issue, tested with Czech Windows 8.1 localization
(cp1250). Strangely, records with diacritics appear correct in GRASS GUI.
See
[[Image(grass_bug_windows_encoding.png, 500px)]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3548#comment:1>
