[GRASS-dev] [GRASS GIS] #3548: sql where statement encoding issue on windows
trac at osgeo.org
Fri Apr 20 03:26:12 PDT 2018
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.4.1
Component: Database | Version: 7.4.0
Resolution: | Keywords: select, where, wingrass, encoding
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Tested also from command line:
# no diacritics, works
C:\>db.select sql="select count(*) from obce where nazev='Kladno';
count(*)
2
# diacritics involved, fails
C:\>db.select sql="select count(*) from obce where nazev='Aš';
count(*)
0
Debug:
D2/5: path to db is
C:\Users\landa\Documents\grassdata\ArcCR500\PERMANENT\sqlite
D3/5: Escaped SQL: select count(*) from obce where nazev='Aš';
D3/5: describe_table()
D4/5: this is not a table column
D3/5: sqltype = 3
D3/5: litetype = 1
D3/5: nkcols = 1
D3/5: sqltype = 3
D3/5: litetype = 1
D3/5: col: count(*), nkcols 0, litetype : 1, sqltype 3
count(*)
D3/5: fetch row = -1
D3/5: col 0, litetype 1, sqltype 3: val = '0'
D3/5: Row fetched
0
D3/5: fetch row = 0
D3/5: db_close_database()
Ticket URL: <https://trac.osgeo.org/grass/ticket/3548#comment:2>
