[GRASS-dev] pygrass v.import_() strange error
Vaclav Petras wenzeslaus at gmail.com
Wed Aug 1 20:06:21 PDT 2018
On Wed, Aug 1, 2018 at 11:03 AM, Pietro <peter.zamb at gmail.com> wrote:
> Hi Yann,
> On Wed, Jul 25, 2018 at 9:34 AM, Yann Chemin <dr.yann.chemin at gmail.com>
> wrote:
>> v.import_(input=adminfile,output="admin",quiet=True,superquiet=True)
> Why are you interested to execute "v.import_(" instead of "v.import(",
> what is it the purpose of this extra underscore in this case?
> It is quite easy to fix this issue but actually I'm not conviced should be
> fixed.
I think Yann is using shortcuts, not execution by providing module name as
a string, so than "import" is really a keyword:
>>> a = 1
>>> a.real
1
>>> a.xxx
  File "<stdin>", line 1, in <module>
AttributeError: 'int' object has no attribute 'xxx'
>>> a.import()
    a.import()
SyntaxError: invalid syntax
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180801/904ba3e2/attachment.html>
