[GRASS-dev] pygrass v.import_() strange error
Yann Chemin
dr.yann.chemin at gmail.com
Thu Aug 2 03:11:55 PDT 2018
Yes I used shortcuts, the Python keyword replacement is forcing pyGRASS to
make v.import_ instead of v.import. However the same "_" scheme is also a
replacement of triple dot separated grass modules 9i.e. r.out.gdal=>
r.out_gdal) and the replacement scheme in running modules assumes that "_"
has to be replaced by a "." .... Thus the error ideed
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180802/9b3b8ee9/attachment.html>
