[GRASS-dev] Compiling GRASS 7.4.2: Issues with FFTW3 / gmath and shared|static libraries
"Peter Löwe" peter.loewe at gmx.de
Tue Aug 7 02:01:04 PDT 2018
Hello list,
I have run into a problem when compiling GRASS GIS 7.4. on a Cluster (SUSE Linux Enterprise Server-based) as a user (non-root): The issue is connected to FFTW for gmath when building GRASS with shared libraries. It disappears when using static libraries, which causes other side effects.
Several required tools were successfully built and installed locally (gdal, geos, netcdf, sqlite and fftw).
This is the current configuration - for shared libraries
GRASS is now configured for:  x86_64-pc-linux-gnu
  Source directory:           /projekte/ploewe/projects/localgrass/grass74_release
  Build directory:            /projekte/ploewe/projects/localgrass/grass74_release
  Installation directory:     ${prefix}/grass-7.4.2svn
  C compiler:                 gcc -g -O2
  C++ compiler:               c++ -g -O2
  Building shared libraries:  yes
  OpenGL platform:            none
  MacOSX application:         no
  MacOSX architectures:
  MacOSX SDK:
  BLAS support:               yes
  BZIP2 support:              no
  C++ support:                yes
  Cairo support:              no
  DWG support:                no
  FFTW support:               yes
  FreeType support:           no
  GDAL support:               yes
  GEOS support:               yes
  LAPACK support:             no
  Large File support (LFS):   yes
  libLAS support:             no
  MySQL support:              no
  NetCDF support:             yes
  NLS support:                no
  ODBC support:               no
  OGR support:                yes
  OpenCL support:             no
  OpenGL support:             no
  OpenMP support:             no
  PDAL support:               no
  PNG support:                no
  POSIX thread support:       no
  PostgreSQL support:         no
  Readline support:           yes
  Regex support:              yes
  SQLite support:             yes
  TIFF support:               yes
  X11 support:                no
Make fails on this configuration as gmath breaks. Running make in the gmath director fails with this error: "relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC"
Running make CFLAGS="-fPIC" in the gmath directory didn't help.
Strangely, changing the GRASS configure script to static libaries fixes the issue, while new issues seem to appear (CTYPES can't be created).
Any advice on the initial FFTW-related issue would be much appreciated.
best,
Peter L.
