[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
GRASS GIS trac at osgeo.org
Sun Aug 12 15:11:10 PDT 2018
  Reporter:  jachym       |      Owner:  grass-dev@…
      Type:  task         |     Status:  closed
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 In tha manual, ESRI_Shapefile is still mentioned as default:
 https://grass.osgeo.org/grass75/manuals/v.out.ogr.html (probably because
 the build server does not support GPKG?)
 Might be worth noting that GeoPackage requires .gpkg file ending to be
 GDAL readable (thought that is probably a GDAL version issue...).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:26>
