[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
trac at osgeo.org
Sun Aug 12 16:10:11 PDT 2018
Reporter: jachym | Owner: grass-dev@…
Type: task | Status: closed
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:26 sbl]:
> In tha manual, ESRI_Shapefile is still mentioned as default:
> https://grass.osgeo.org/grass75/manuals/v.out.ogr.html (probably because
the build server does not support GPKG?)
That's right. It is a meanwhile old Debian server.
> Might be worth noting that GeoPackage requires .gpkg file ending to be
GDAL readable (thought that is probably a GDAL version issue...).
Should that go into the manual?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:27>
