[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
GRASS GIS trac at osgeo.org
Mon Aug 13 00:14:44 PDT 2018
  Reporter:  jachym       |      Owner:  grass-dev@…
      Type:  task         |     Status:  closed
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 Replying to [comment:27 neteler]:
 > > Might be worth noting that GeoPackage requires .gpkg file ending to be
 GDAL readable (thought that is probably a GDAL version issue...).
 > Should that go into the manual?
 Just double checked with newer GDAL version (2.2).That can open
 GeoPackackages also with non standard endings. So, seems to be a GDAL 2.0
 issue:
 https://trac.osgeo.org/gdal/ticket/6396
 However, - according to the GDAL ticket above - newer GDAL versions should
 issue a warning if no standard endings are used...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:28>
