[GRASS-dev] SOLVED: Trunk fails at configure phase on Ubuntu 18.04
Maris Nartiss maris.gis at gmail.com
Fri Aug 17 02:30:49 PDT 2018
2018-08-15 23:19 GMT+03:00 Markus Neteler <neteler at osgeo.org>:
> That's strange. I recently updated the Dockerfile in trunk to use
> 18.04 and it works smoothly:
> https://hub.docker.com/r/neteler/grassgis7/~/dockerfile/
> Perhaps compare to your install procedure?
> Markus
Thanks, Markus.
As Docker didn't contain anything suspicious, I almost gave up but
decided to give the last shot to LC_ALL=C. Seems that I must set
LC_COLLATE=C before running ./configure. My previous value was
lv_LV.UTF-8.
Apparently my locale and GRASS build system do not play along nicely.
Māris.
