[GRASS-dev] [GRASS GIS] #3622: r.out.gdal export in USGSDEM format takes very long time and finally crashes
trac at osgeo.org
Fri Aug 17 04:58:07 PDT 2018
crashes
Reporter: dido | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: Raster | Version: 7.4.0
Keywords: r.out.gdal export USGSDEM long time | CPU: x86-64
crashes |
Platform: MSWindows 7 |
I cannot attach any test raster because the one that manifests the problem
is very large. Here I apply raster metadata (I suppose any raster of this
size will do):
r.info map=BGMdem_8x8m_holes_filled_feathered at PERMANENT
| Map: BGMdem_8x8m_holes_filled_feat Date: Fri Aug 17 13:30:15 2018
| Mapset: PERMANENT Login of Creator: a
| DataBase: E:\mapping\GRASS7DB
| Title: BGMdem_8x8m_holes_filled_feathered
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: DCELL
| Rows: 52101
| Columns: 77901
| Total Cells: 4058720001
| Projection: UTM (zone 35)
| N: 4928368.63825695 S: 4511560.45143113 Res: 8.00000359
| E: 663749.15806402 W: 40538.62472039 Res: 8.00003252
| Range of data: min = -52.070711097653 max = 2925
| Data Description:
| generated by r.mapcalc
| Comments:
| if(isnull(defekti_rast_buf_recoded), BGMdem_8x8m_holes_filled,
| if(defekti_rast_buf_recoded < 100, BGMdem_8x8m_holes_filled * (100 -
| defekti_rast_buf_recoded) / 100 + ALOSdem_interp *
| defekti_rast_buf_recoded / 100, BGMdem_8x8m_holes_filled))
At crash time progress indicator has not advanced at all. Tool output
follows:
r.out.gdal -f --overwrite
input=BGMdem_8x8m_holes_filled_feathered at PERMANENT output=E:\tmp\BGM-dem-
f5p-csovp-wbf-cas-clgeo-s0_UTM_blended_20180816.dem format=USGSDEM
type=Int16
Driver <USGSDEM> does not support direct writing. Using MEM driver for
intermediate dataset.
WARNING: Precision loss: Raster map
<BGMdem_8x8m_holes_filled_feathered at PERMANENT> of type DCELL to be
exported as Int16. This can be avoided by using Float64.
WARNING: Forcing raster export
Checking GDAL data type and nodata value...
Using GDAL data type <Int16>
Input raster map contains cells with NULL-value (no-data). The value
-32768 will be used to represent no-data values in the input map. You can
specify a nodata value with the nodata option.
Exporting raster data to USGSDEM format...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3622>
